Use statistics to help you monitor OSPF performance.
View the OSPF interface statistics:
Switch:1>show ip ospf ifstats
OSPF Interface Statistics - GlobalRouter
---HELLOS---- ---DBS--- -LS REQ-- --LS UPD--- --LS ACK---
INTERFACE RX TX RX TX RX TX RX TX RX Tx
192.0.2.3 76035 76355 33 32 4 9 2483 2551 2525 1247
192.0.2.8 76038 76349 0 0 0 0 0 0 0 0
Variable definitions
The following table defines parameters for the show ip ospf ifstats command.
Variable |
Value |
<1-4059> |
detail |
Displays the details of the OSPF. |
mismatch |
Specifies the number of times the area ID is not matched. |
vrf WORD<1-16> |
Specifies a VRF by name. |
vrfids WORD<0-512> |
Specifies a range of VRF IDs. |
